When you have to find No1 piston at TDC on the compression stroke hold a thumb over the plug hole while a helper slowly cranks the engine until you feel pressure against your thumb. Then drop a long plastic straw on top of the piston. Then you watch the straw rise as a helper slowly cranks the engine. When the straw quits rising No1 piston should be at TDC on the compression stroke. Hal
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
