Re: motors
Posted by Dave S. on August 20, 2014 at 09:30:15 from (208.92.171.75):
In Reply to: motors posted by F30 on August 19, 2014 at 14:51:51:
It works very well, installed a 300 with350 sleeves and pistons in a 45 h. Below is a list of what I used to install.
To install 300 or 350 engine in a H
1. If you are planning on using the 300/350 live pump be sure to use the timing cover and related parts for 300 or 350 or late H (early H bolt holes are different).
2. Use the H fan, 300/350 fan is to large in diameter.
3. Use the air cleaner & pipe from air cleaner to carburetor for a SH, the one for an H is to small for the 300/350 carburetor.
4. Use a 300/350 or SH flywheel and a SH clutch plate and pressure plate if you are going to pull it hard (H flywheel, clutch plate and pressure plate will work but is smaller, H 10”, SH/300/350 10 ½” ). Also if you use the 300/350 flywheel measure the distance from crank mounting flange to starter ring gear (might have to drive it back a little).
5. Use H governor or use throttle shaft from H governor in 300/350 governor.
6. Have to convert vent from back of head on H to vent from valve cover for 300/350.
7. Change oil pressure fitting from H onto 300/350 block before installing side rail channels (fitting is hard to change after rails are installed). 300/350 had small line from block to gauge.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
