Re: Preasher relief valve
Posted by george on January 01, 2001 at 10:53:50 from (172.169.20.60):
In Reply to: Preasher relief valve posted by Bill Jolley on January 01, 2001 at 09:05:26:
Can you be a little more specific? The only pressure releif valve I can think of would be an internal component of the hydraulic control unit.
If this is the one you are speaking of, you need to remove the control unit, remove the bottom plate, and the releife valve is right there...it is a slotted screw with a hole in the center and a nut around the perimeter.
What are you working on fixing?
Post A Followup
: Re: Re: Preasher relief valve
