Re: F20 carb problems
Posted by dodger42 on August 20, 2014 at 17:07:00 from (76.112.97.194):
In Reply to: F20 carb problems posted by robgIN on August 20, 2014 at 15:21:28:
Follow-up: I removed the main needle and jet, and noticed a passage I was not aware of. Of course, it was blocked, so I cleaned it out with carb cleaner. While I was in the neighborhood, I took the fuel line off, and ran carb cleaner through it, and blew it out with 100psi air. After I put it all back together, it started right up, and ran smoothly with no choke. Just about that time, the rotten old fan belt let go, so I called it a night. I'm pretty confident that issue is resolved. I thank you for your replies and advice.
