Re: I'm gonna need a clutch soon
Posted by Gary in SE MN on August 20, 2014 at 19:50:27 from (24.197.188.179):
In Reply to: I'm gonna need a clutch soon posted by mattwillson on August 20, 2014 at 17:53:40:
IIRC only late M's had 12 inch clutch. Others will know but I think it is possible to do a flywheel swap to go from 11 to 12 inch clutch. Depending on how serious you are there are shops that build clutches for 656-686 that are 11 inch and can take lots of hp. This advice worth what you paid for it.
