Re: C-36 Fast Hitch Disc - Where to buy parts
Posted by 504 on August 20, 2014 at 19:50:38 from (199.127.54.155):
In Reply to: C-36 Fast Hitch Disc - Where to buy parts posted by JakeBrakeIH on August 20, 2014 at 09:32:52:
Blades are either 16 inch or 18 inch, I put 18s on mine. The bearing is shone as three pieces, top, bottom and a sleeve that the axle runs through, the halves clamp over it.
I would and did install new blades(generic farm store blades)and grease it every time I stop, I did not even check the bearings.(they turned)
Today's Featured Article - Introduction to the Gibson Model D - by Brandon Burnett. The Gibson Manufacturing Corporation was founded 1946 by Wilber Gibson. The Gibson tractors were made from around 1948 to 1952. The picture shown here is of a 1948 Gibson model D. If you notice, this tractor is driven with a lever. You could get a attachment to convert it to a steering wheel. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
