Re: Should I cut down fast hitch prongs???
Posted by mkirsch on August 21, 2014 at 05:17:30 from (72.45.143.81):
In Reply to: Should I cut down fast hitch prongs??? posted by JakeBrakeIH on August 19, 2014 at 18:27:24:
Nobody said it won't work. The issue is in permanently modifying a somewhat rare, definitely irreplaceable, piece of farm equipment.
Going from small to large is easy. All you need is a 1/2" shim under each prong, and IH even made shims for this. Reproduction shims are out there too, but it's really something you could build in your own shop with a chunk of 1/2"x1" flat bar, a drill, and two roll pins.
