Re: Cub offset PTO question
Posted by Karl in MD on August 21, 2014 at 12:37:47 from (167.102.133.216):
In Reply to: Re: Cub offset PTO question posted by old on August 21, 2014 at 12:32:36:
The Cub PTO was driven direct from the engine so it did turn "bassackwards". The Oliver PTO was also driven direct from the engine, but it was geared to reverse it to clockwise rotation and 540 RPM.
