Posted by rustyfarmall on August 22, 2014 at 07:22:34 from (208.126.186.41):
In Reply to: IH 400 Sleave seals ? posted by husker44a on August 22, 2014 at 06:29:54:
Before ordering, you might want to examine the top of the block. There should be a code of some sort, stamped into the block, right next to each cylinder. Hopefully, those codes are all the same. If not, you may have one or two cylinders that are a bit bigger in diameter, and will require a thicker sleeve. I believe there are other folks who have encountered the discrepancies, and had to "custom" order the sleeves. Probably doesn't happen too often, but knowing what you are getting into beforehand might save some frustration later.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
