Posted by D Slater on August 22, 2014 at 08:03:35 from (184.14.176.27):
In Reply to: IH 400 Sleave seals ? posted by husker44a on August 21, 2014 at 21:05:35:
Keep in mind that you have a piston pin size change for a 400 engine when ordering. Should list a serial number break on the kits or say you need to use adapter pin bushings. That will be the engine serial number listed and not the tractor on the change. Thinwall sleeves were not designed to be a heavy press fit in the block. Lots of them will slide in from 1/3 to 2/3 by hand when clean and lightly oiled. Then you run into some that will push all the way in by hand. Then its up to you to decide to use as is, use it with locktight sleeve sealer or other, or go with a custom sleeve or other.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
