First assess what HP rating you have now & then match the clutch to the HP application. Issue is, too high clamping force
(button clutch) is really hard on tranny gears & final drives.
As stated above you will need to know what diameter clutch you have now & go from there. Enough $$ and anything is possible. Any reliable place that relines or sells heavy duty clutches can help you.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
