Re: converting from magneto to distributor
Posted by NNP on August 23, 2014 at 05:51:28 from (66.66.112.196):
In Reply to: converting from magneto to distributor posted by DeanesLC on August 22, 2014 at 18:47:55:
like Gene posted, pretty simple if you want to change.
I, too, like my mag tractors.
soon as the engine starts to rotate, they are running.
couple of my workers have pretty much no wiring at all.
mag, 12v battery hooked to the manual push/pull rod starter.
That's it. Without the ignition draw, and with instant starts, I just need to remember to put a battery tender on it once a year or so.....
If your mag's fairly expensive coil has expired, just wire in an external round coil for battery ignition. works fine.
And if you own your tractor long enough, there will be a hand crank start situation eventually. Then you will be glad the mag is still on it.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
