When my 1086 was new and set by the factory I was pulling a 6/16 plow at 5 mph burning almost 5 gal per hour. About 145 HP.
I turned up the fuel to get 175 hp and pulled that plow 6.5 mph. Burned about 6.5 gallon per hour.
I used about the same gallons of fuel per acre to plow but got it done faster.
If you are pulling the 1086 hard and the fuel is turned up it could burn 8 gallons an hour at 200 hp. I did that for awhile but took the hp back to 175 cause I couldn't get the hp to the ground. Too much spinning.
How many trips did you make to get that 10 acres ready?
When I plowed, disced, field cultivated and planted, I would burn about 4 to 5 gallons per acre.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
