Re: Need help installing crank pulley
Posted by gene bender on August 23, 2014 at 08:32:58 from (67.55.226.121):
In Reply to: Need help installing crank pulley posted by RTR on August 23, 2014 at 08:17:43:
I have a bracket assy and use a hy jack to press them on as some go on easier than others. Same thing on removing use a plate behind the pulley and three jaw puller. Is the area where the seal rides clean and no grouve cause if it is worn where the seal rides it will leak.Mite need a speedy sleeve to get a good surface in that area.
