Re: f20 clutch plate seized after sitting too long?
Posted by Tom Fleming on August 23, 2014 at 09:48:44 from (67.20.239.72):
In Reply to: f20 clutch plate seized after sitting too long? posted by michaelr on August 22, 2014 at 08:28:43:
The best way is to remove the clutch housing (not a terrible job) and remove the pressure plate. That way, you can clean things up.
I have had some limited success with going in from the inspection plate and working my way around with screw drivers with the clutch peddle held down.
You also need to take the inspection plate off in any case to make sure your issue isn't a mouse nest. Common problem on these old girls that sit for awhile.
