A battery ignition unit will give you a smoother running engine at your lower engine speeds and especially low idle. On a magneto, as soon as the engine starts the timing is full advance which is normally 35 degrees on the H4 magneto. Now, problem with battery ign units is you need to know which one you need. Most came from factory with a 40 degree advance when they still used the std bore and cast iron pistons. A flat head increased bore gasoline head , aluminum piston should have a 30 degree advance, if fire crater it should be 22 degree advance. So, you can see. Depends on what head and pistons you have for best fit. Most used ones are worn out and advance way too much at low speeds. Most rebuilt ones are 40 degree advance. When I talk advance, that means it should be fully retarded at low idle and gradually advance as you speed the engine up so it reaches full advance at rated engine speed. Mags are ok but IH didn't change to battery ignition just to add more parts to the system.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
