Re: exhaust manifold correct color
Posted by RTR on August 23, 2014 at 18:46:49 from (98.83.136.172):
In Reply to: exhaust manifold correct color posted by Bob on August 23, 2014 at 11:41:38:
Like Gene Said. I will wire wheel them clean and paint them with primer and high temp black paint on the exhaust portion and then mask and paint the 2 lower intake tubes red with the tractor. Essentially the black with burn off over time and the lower will stay red giving you the original look. When doing a restoration the black makes it "pop" and it does last on there for a good while if not used much.
third party image
This post was edited by RTR at 18:47:56 08/23/14.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
