Re: Farmall 400 sleave (deck stamping)
Posted by D Slater on August 24, 2014 at 04:39:25 from (184.14.176.27):
In Reply to: Farmall 400 sleave (deck stamping) posted by husker44a on August 23, 2014 at 19:55:09:
Higher the letter past A the slightly bigger the block bore was. Unless you get a sleeve that came out a bigger OD than usual now. Thinwall sleeves will go easy in that block.
