Re: starter motor will not stop running
Posted by gene bender on August 24, 2014 at 18:42:15 from (67.55.226.121):
In Reply to: Re: starter motor will not stop running posted by homebre973 on August 24, 2014 at 15:02:11:
If you had a short the wire would burn up. Your sww must be stuck in the start mode as thats the position it needs to be for the soleniod to energize then when you release the sw it springs back to run and then the starter would stop as only time starter should turn over is when you hold the key to the start position. Sounds like you better get someone who knows how to wire and trouble shoot your system.
