Re: farmall c hydraulic oil
Posted by SDE on August 24, 2014 at 19:00:48 from (184.157.216.215):
In Reply to: farmall c hydraulic oil posted by transtar61 on August 24, 2014 at 17:10:12:
If the reservoir is empty, take a few minutes and remove the filter. It is on the right side and slides out after you remove 4 bolts. Hy-Tran or comparable fluid or a non-detergent 10 or 20 weight oil will work.
SDE
