Re: Farmall carb solenoid valve
Posted by Bob on August 24, 2014 at 19:57:04 from (64.255.159.192):
In Reply to: Farmall carb solenoid valve posted by rick56 on August 24, 2014 at 19:37:09:
If the needle has already been cut off of the solenoid, the jet inside the threaded bore is already controlling the fuel flow, and you already without "backfire at shutdown protection", so simply hack the remains of the solenoid off of the threaded brass part and solder the hole closed in the brass part, then screw it back in place. BT,DT, and 503 combines, years ago.
This post was edited by Bob at 09:50:10 08/25/14.
