Re: farmall A plow?
Posted by gene bender on August 24, 2014 at 20:30:12 from (67.55.226.121):
In Reply to: farmall A plow? posted by badger bob on August 24, 2014 at 12:54:21:
That wont work as you have no way to guide or set depth. When you were here should have looked at my set-up with the irrigation shovel works fine for digging them. I use the rear tooling on the cult with the shovel mounted in the center. Do you have a digger with the shaker. I have one you can have needs another guide wheel
