Re: farmall c hydraulic oil
Posted by DaninKansas on August 25, 2014 at 05:57:39 from (24.248.193.103):
In Reply to: farmall c hydraulic oil posted by transtar61 on August 24, 2014 at 17:10:12:
As mentioned below use this as an apportunity to clean the filter and possibly the entire reservor. You can refill it with most any hydraulic fluid - I suggest Super Tech hydraulic fluid (NOT the R&O type)from Walmart. When this tractor was new I beleive the oil used "Touch Control Fuild" pretty much a slightly modified 20W nondetergent motor oil so any current automotive or ag hydraulic oil will be better than what was originally used.
I know a lot of people use the old Ford Type F transmission fluid because they can find it pretty cheap.
