Re: Uncles 826
Posted by DeltaRed on August 25, 2014 at 06:45:19 from (67.40.59.57):
In Reply to: Uncles 826 posted by C.R. on August 25, 2014 at 01:45:47:
I dont know of a way to 'troubleshoot/diagnose' a pump on the tractor.You have to remove it and take it to a pump shop.$2000 is about right for a pump rebuild,those pumps are obsolete,so parts are expencive.The tractor is still worth fixing!Call Abilene Machine.They do pumps.We had one done on a JD 4430 coulpe years ago. $1100.We were well satisfied.Run a compression test first before you pull the pump.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
