Re: Super C sleeves
Posted by mkirsch on August 25, 2014 at 10:52:29 from (72.45.143.81):
In Reply to: Super C sleeves posted by BoonvilleKid on August 25, 2014 at 10:09:35:
The crankshaft and bearings are completely separate from the cylinder bore. You would use the same connecting rods regardless of bore, so only do what is necessary to get the crank journals within spec. You might need UNDERsize bearings, you might not. Depends on how bad the crank is and what the machine shop does to it.
The head does not need to be machined for different sleeves. Sleeves go in the BLOCK. On a Super C the block needs to be machined to fit the 3.25" overbore sleeves and pistons.
