Re: Farmall international 'h'
Posted by Bob R on January 01, 2001 at 15:52:00 from (209.198.116.185):
In Reply to: Farmall international 'h' posted by Robert J. on January 01, 2001 at 13:59:08:
I would check the valve clearances . Should be .017 hot . My tractor would start and idle and run (I thought )well , till it warmed up . Then It would run rough and backfire . I pulled a plug wire off at a time to check for rpm drop . Ther was a noticable rpm change in all cylinders but not in no two . A rpm drop tells you your getting power . No drop and that clyinder is dead . Then removed the valve cover , and found a broken push rod . Got a new push rod and figured I better make sure the intake valve will open , was so lucky I didnt crank , becuase that valve had been stuck for a long long time . The head was taken in and rebuilt . It was very worn . The compression was showing in number two clyinder , but was a little low . The spark plug at a time trick will reveal a lot . Please post what you come up with A lean fuel mixture is a sign of back fire. Also if the timeing is to far advanced will back fire . Did you time static at tdc ? Gas in oil pan may be the valve issue or blow by from worn piston / rings .
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
