Re: H Belly pump flow rate
Posted by Janicholson on August 25, 2014 at 17:49:03 from (74.60.94.18):
In Reply to: H Belly pump flow rate posted by Dan T in MO on August 25, 2014 at 12:47:07:
Between 7.5 and 8 gpm based on load wear and temperature, at full load speed. Into a bucket, it will do 8 gpm . Jim
