My F20 was stuck from sitting 20 years without moving or starting. After I got it running again, I checked in the inspection hole, but fortunately, no evidence of mice. So, I jammed a wood block between the clutch pedal and the housing, put the trans in 4th gear, and dragged the tractor maybe 15-20 feet with my 8N (when it started rolling easy, I knew it freed up) Of course, the mag was grounded out, so it wouldn't start and come roaring at me-it would definitely be safer to have someone on the F20,too.
I then started the F20 up, and the clutch was free. I drove it around a bit, then parked it and jammed the wood block back in again behind the pedal, and let it idle a bit before I shut it down. I'm going to leave the block in, like the other poster suggested.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
[More Ads]
