Posted by wayne in mn on August 25, 2014 at 18:34:15 from (71.8.150.168):
In Reply to: h and m brakes posted by dewy on August 25, 2014 at 18:19:27:
Transmission may be in 2 gears at once. Push in the clutch & try to move the tractor. If brakes are stuck, disconnect the pedal & remove the screws holding the brake cover. Pry the cover off. You may have to take the brake lever off first; loosen the clamp bolt and split the clamp with a small chisel. Use a modified diagonal cutter(grind the flat side so it comes to a sharp point at the cutting edge) to remove the 1/2 moon key and then the cover should come off.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
