Battery cables being sized for 12volt is most common. They need to be 0gauge wire to move the amps from the under seat to the starter. A good ground strap bolted to more than tin bat box is also needed. Low voltage from poor #4 sized cables does not allow the ignition to fire the plugs. A dragging starter motor will also make the same issue, as will a battery going bad/not charged fully. Jim
