Re: IH 674- Hole in hi pressure injector fuel line.
Posted by jimb2 on August 26, 2014 at 13:49:02 from (99.241.118.87):
In Reply to: IH 674- Hole in hi pressure injector fuel line. posted by Slim H on August 26, 2014 at 08:41:04:
Hi Slim, see parts caseih.com at:
http://partstore.caseih.com/us/ReisEquipmentCarp/parts-search.html#epc::mr48004ar1285957
I believe you are describing the injector fuel return line. CIH parts calls it leak line
Product No: 3055606R91.
Never had any success fixing them. Newer models had some kind of plastic material replacing the braided rubber sections.
PS, the leak will worse as the temperature gets colder.
JimB
