Re: New tires vs old tires
Posted by dej(Jed) on August 27, 2014 at 06:52:34 from (141.189.113.1):
In Reply to: New tires vs old tires posted by PretendFarmer on August 25, 2014 at 18:44:58:
The 11.2's are smaller and your speed will be affected. Also you will have less width for traction. The tire profile is different. I always pull better with an old road worn tire. I run a psi equal to the class I am pulling in. In the 6000 lb class I run 6 psi, in an 8000 lb class I run 8 psi. This allows the tire to crush out to it's widest when it is under a load.
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
