Re: WD9, what do I do?
Posted by Roy Prins on August 27, 2014 at 17:44:28 from (96.31.24.201):
In Reply to: WD9, what do I do? posted by Wheaty on August 27, 2014 at 15:40:04:
10-4 on the red power add -- not cheap tho -- if you have not pulled the sleeves try checking the bore then check the pistons for wear -- mayby all you need is a set of rings-- a little play in things make-em run good-- good luck-- Roy
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
