Re: 300 U steering box change out need advice
Posted by MarkRobke on August 27, 2014 at 18:00:04 from (75.89.159.107):
In Reply to: 300 U steering box change out need advice posted by 300dave on August 27, 2014 at 06:50:22:
I believe you can use a jaw type puller on the steering wheel.You can whack the rounded side of the pitman arms with a big hammer and they should pop off;I believe there are chisel marks on their face for alignment.On mine I don't remember having to helicoil the mounting holes, but that would work well if needed.I do remember using soft locktite on the mounting bolts.Congratulations on finding a box!Good luck,Mark.
