Re: 8 volt battery in a Super M
Posted by Bob on August 27, 2014 at 21:03:49 from (64.255.159.192):
In Reply to: Re: 8 volt battery in a Super M posted by john *.?-!.* cub owner on August 27, 2014 at 20:34:03:
"Voltage regulator is not going to kick in and tell the generator to charge till the voltage goes below the 6 volts it was made for."
Actually, voltage regulators for "6 Volt" batteries are set at as much as 7.4 Volts.
With an 8 Volt battery, the regulator needs to be set up to about 9.8 Volts.
