Re: 8 volt battery in a Super M
Posted by Bob on August 27, 2014 at 21:18:05 from (64.255.159.192):
In Reply to: Re: 8 volt battery in a Super M posted by 504 on August 27, 2014 at 21:03:21:
"Pull the regulator cover, and adjust the points till it works,"
504, that sounds like a recipe to "let all the smoke out"
What he needs to do is to SLIGHTLY increase spring tension on the voltage regulating relay on the VR.
NO "point adjustment" is needed.
