Re: 1206 'value'
Posted by John A on August 27, 2014 at 21:23:56 from (64.128.16.238):
In Reply to: 1206 'value' posted by DeltaRed on August 27, 2014 at 09:05:14:
Delta, The question IS what will it take to put the tractor up in shape and be a Main Stay tractor in you Stable? Is this a special tractor or anything, Seams like that is way too high for the work needed and what one has after all work is done! waay too much repair it is hard for me to justify in that condition!
Estimate of Repair, Replace, Fix
Split tractor to replace TA, while in Clutch, P. Plate, throw out bearing..................+-$3500
Gaskets, and Hoses seals..................+-$.500
Front tires...............................+-$.200
Rear tires................................+-$1200
Front-end repair or replace...............+-$1200
Remove cab, install Open station items....+-$1000
3pt linkages, replaced (used).............+-$.500
Seat......................................+-$.150
Seat torsions....(both),..................+-$..60
a ruff calculation get you at...........----.......+-$8200 in repair not counting the purchase price!+-$4000
You will be in in the neighbor Hood of...$12,000K after you get through with all the incidentals!
Unless this is a winter project, work on as you get time and funds freed up Would you be better off buying one that is ready to go ?? !!
Later,
John A.
