Re: farmall 450 diesel - what do you know about them?
Posted by John LaBoyteaux on August 28, 2014 at 07:11:03 from (63.80.39.253):
In Reply to: farmall 450 diesel - what do you know about them? posted by michaelr on August 28, 2014 at 06:36:47:
If the 450 and MD have been sitting a long time you may have to clean out the diesel system including disassembly of the injection pump which may be best done by an experienced diesel shop. Get them running on gas first and that will tell you a lot. Sticking butterfly valves in the intake manifold are a common frustration in starting until you get them right. I don't know how much you are farming but I would not hesitate to use an MD or 450 for tillage. The MD did have a problem with head cracking because of inferior iron and a complicated casting. I think IH had corrected that by the time they got to the 450. Avoid overheating and let them cool down at idle before shutting down.
