Re: Farmall 400 Hydraulic System
Posted by Tim Nichols on August 28, 2014 at 07:27:27 from (65.185.107.28):
In Reply to: Farmall 400 Hydraulic System posted by mkirsch on August 28, 2014 at 04:56:18:
I wanted to change the fluid and filter due to low pressure when my steering, loader and fast hitch started moving really slow. I checked the fluid and it was at the proper level.
I drained the fluid and pulled the filter noticing the brass mesh on the filter was about half gone. Checked in the resovoir and did not find any of the mesh.
Installed the new filter and filled with fluid and have no pressure at all. System not making any noises.
Looking for ideas of where the mesh may be blocking the system at, if I need to tear the system apart or is a flush possible to clear the blockage.
Tim
