I have a 400D and like it. As already said the fuel system up to the pump will need to be disassembled and cleaned and new filters put in.
Also a high probability the fuel pump seal will leak into the reservoir for the injector pump. The injector pump has its own oil reservoir seperate from everything and fuel leaking in will dilute the oil and cut it's lube ability. It has a check cock on the side, open it and see what comes out. If nothing then crack the drain plug on the pump and see what comes out.
Make sure rack inside pump is not stuck prior to starting.
I like mine and they are very interesting but I would like to hear one run before committing to a price much above what it weighs. There is potential for problems that could lead to significant financial discomfort. Of course diesel parts are worth more and the WFE boosts the value. I think an even grand is more in line, at least in this region that would be fair.
When I bought mine it would not run on diesel but I did get to drive it around on gas and check everything out. It had been sitting for a couple of years but had been stored inside. I dropped the oil pan and cleaned the fuel system and it was good to go.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
