Re: 6 Volt starter on Farmall 100
Posted by mkirsch on August 29, 2014 at 05:17:10 from (72.45.143.81):
In Reply to: 6 Volt starter on Farmall 100 posted by Philip Way on August 29, 2014 at 04:49:08:
No, it should not burn out immediately. If it does, it is because your starter was no good to begin with, not because of 12V.
You CAN burn the starter out by cranking and cranking and cranking and cranking and cranking and cranking and cranking and cranking and cranking and cranking and cranking and cranking and cranking and cranking and cranking on the engine when it won't start. If the engine does not fire after 10 seconds of cranking at most, you have a problem that needs to be fixed before cranking on it some more.
Typically the battery cable issue John T indicates takes care of itself. People always use the same crappy crusty old battery cables you had before, and they add enough resistance to the circuit.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
