The type of drive your starter uses depend on a fast start of armature rotation to get the drive to engage. It has an inertia type drive with a helix spline to move the drive into position in the ring gear. The armature has to start very quickly so the drive will slide down the helix and engage the ring gear before it starts to turn with the armature. If the armature starts too slowly or the helix is sticky the drive will start to spin before engaging the ring gear.Running at 12 volts actually makes this type of starter engage better. The down side of the more rapid rotation is that it puts more stress on the spring in the drive when it has to start to turn the engine. On the other hand the same drive is used on an M and many of them have been used for years with 12 volts and have not and broken springs. It is highly unlikely you will ever see it happen on a 100.
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
