Posted by john *.?-!.* cub owner on August 29, 2014 at 12:51:49 from (99.195.115.190):
In Reply to: IH 444 question/problems posted by john *.?-!.* cub owner on August 28, 2014 at 07:16:45:
Thanks Owen, that helps. I can push the field relay of the regulator closed, and it will kick in and charge full scale on the ammeter till I turned off ignition. Changing the regulator did not help. Looking at that diagram it appears the alternator may have a bad diode causing the regulator not to receive voltage to pull the field coil in, or I am wondering if the idiot bulb (not charging light) could cause a problem by being burned out.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
