6v or 12 v solenoid
Posted by Andrew Kligerman on August 29, 2014 at 12:59:45 from (209.179.60.56):
I have an IH 340 utility tractor that needs a
starter solenoid. I took the old one off and it is
a DR1465 6v. However, the tractor runs on a 12
volt battery Should I replace the solenoid with a 6
volt one as the one I took off or go with a 12 volt
solenoid. I am not the original owner obviously, so
I don't know what else might have been done to the
electrical system. Thanks
