Re: Farmall 400 Hydraulic System
Posted by rhtx55 on August 29, 2014 at 15:01:49 from (68.191.209.251):
In Reply to: Farmall 400 Hydraulic System posted by Tim Nichols on August 28, 2014 at 04:37:17:
Since you say there is no pressure at all, I would first take the oil lines off going to the pump & check for any obstructions on both the pressure & return sides. Once back on I would remove the small plug on the top of the pump and fill with Hydraulic oil.
Then replace the plug & start & let idle to see if the pump is free of air, or if things start working.
