Caps are the most common cooling system failure. Look closely, there s a small mushroom like disk (atmospheric valve) on the bottom center, it should be held closed by a very light spring. Its rubber should be in good condition, as should the rubber that seals against the neck flange. The tension spring that applies pressure is also a failure point in that it can rust or corrode away. The atmospheric valve is to allow the cooling system to draw in air as it cools off, this prevents collapsed hoses or components like top tanks. New caps are cheap. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
