Hi, as Jim said rad cap, also check that water pump is not leaking down the front of the block. Also first thing in morning before starting the tractor, loosen the oil pan drain and make sure that there is no coolant coming out before oil. The older German Diesel had a problem with the O-rings at the bottom of the sleeves leaking. Does your 685 have a coolant filter to prevent sleeve cavitation? I know 95 series have it and it is supposed to be changed as per Operator;s manual.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
