Re: Two questions - Farmall H
Posted by bassmasta76 on August 30, 2014 at 11:14:18 from (198.232.63.61):
In Reply to: Two questions - Farmall H posted by bassmasta76 on August 30, 2014 at 09:04:26:
Thanks for the replies, I appreciate the info.
Glad to hear that I can remove the Governor without having to worry about timing. I think some of the other models in the letter series you may need to worry about timing? Of course, I've read this online and take that with a grain of salt. Regardless, it doesnt matter here.
As for the manifold, I will just get a new gasket. Regarding the coating of the manifold, I've had quite a bit of luck in the past with Eastwood products on car exhaust manifolds. Their coatings are designed for high temp applications... I'd post a link but am not sure if it will get pulled or not... just search for Eastwood Exhaust coatings... they support up to 1200-1300F and bake on as the part gets hot.
thanks!
--b
