Re: keep or loose 3 brush generator on super A
Posted by mrl from ohio on August 30, 2014 at 18:25:27 from (162.213.224.3):
In Reply to: Re: keep or loose 3 brush generator on super A posted by John T on August 29, 2014 at 15:46:09:
am I understanding that the three brush can work with a voltage regulator? my tractor does not appear to have the light switch used with the cut out relay. I assumed the tractor was originally regulator controlled and someone at some time put an incorrect generator on it, but I am reading that some tractors came out with 3 brush generators and regulators? . I will look at the third brush adjustment location next week end. I don't know if this observation has any value, but if I tap the regulator with a screwdriver handle the voltage jumps to around 6.5 to 7.5 volts and drops over a matter of a minute or so to around 1 volt and change. rap on the regulator again and it starts the same cycle again.
