Re: Gas problem?
Posted by CNKS on August 30, 2014 at 18:26:06 from (216.144.104.128):
In Reply to: Gas problem? posted by Farmall4856 on August 30, 2014 at 14:47:05:
What repair kit did you get and what did the instructions say? The needle for the main jet on the SM carb gives max power at 5 turns out. If you adjusted it as for the M, (in until rough, out until smooth) it won't have any power.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
